Remote code please!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by PDES, Oct 14, 2003.
  1. PDES
    PDES
    Team,
    Has anyone found a code for the Oneforall (4 way) remote that will operate a Sky+ plus box?
    TIA, David
  2. leesbriggs
    leesbriggs
    I just used first pace 1. Use the scroll button and you'll get the record fuctions aswell:D
  3. PDES
    PDES
    Thanks for the help but it didn't work. So I spoke (at £1 per minute!!!) to OFA. They said my remote wouldn't handle Sky+
    So. I have just bought a OFA 6 (model 7562) on the recommendation of OFA themselves. But I STILL can't find the code.
    Any further help gratefully received.
    David
  4. leesbriggs
    leesbriggs
    Should have got a 6 in one kameleon! Paid £30 for mine (£70 in the shops!!!) from ebay. FULLY controls my Sony digital TV, sony Davs880 and my sky plus!
    Also, OFA have a freephone number.... 0808 1000306
    Most of the remotes afaik have a download facility that you can download over the phone. I prefer to do that as you tell them all the equipment you have and they program all the codes in 1 download.
    Hope this helps.
  5. craige247
    craige247
    Dec 1, 2003
    16
    Hi leesbriggs, Did OFA give you the codes for sky+ over the phone or have you got them?? I have the kameleon 6 and need the codes.
    Thanks:confused:
  6. leesbriggs
    leesbriggs
    Hi, just ring their helpline, give them all your equipment model numbers and they will download a code to your phone, over the phone!
