hi im trying to help a friend find a sky remote code for a new LG tv. its model number "LG42PC56." He bought it only 2 weeks ago and is using a revision 6 sky remote control. So far hes tried 0065, 0206, 1206, 0584 and 0398. Ive also suggested trying the search and scan method ? Correct me if im wrong but the search and scan method goes: tv - select & red (double flash) standby, tv, standby, tv, standby, tv, etc until it finds the correct code. Tried this for about 2 minutes but no luck. I tried searching the forums because ive seen the instructions for this procedure before but couldnt find it again. Am I doing it correctly? also another question, if i try the search and scan but use one of the LG codes for example do tv- select & red - tv - 0584 - standby, tv, standby, tv, standby, etc...does this narrow down the search to look through the different LG codes ? any help appreciated, cheers.
