Remote: Cambridge Audio M1 Enhanced +
Discussion in 'Home Cinema Control & Remote Controls' started by Dunky, Jun 11, 2002.
  1. Dunky
    Dunky
    Nov 15, 2001
    60
    Surrey
    I'm on the look-out for a cheapish learning remote to replace the hundreds of chunks of black plastic I have cluttering up my coffee table. I'd quite like an LCD touchscreen jobby so that I can size/position the buttons myself.
    I was wondering if anyone out there has used the Cambridge Audio M1 Enhanced + remote available from Richer Sounds. If so, is it any good?
    Cheers.
    Duncan
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Lots in the past post on this one, use the search engine. Basically it is a tough and useful device, not a Pronto but good value and easy to use.
