Relysis LCD to Phillips Freeview box
Discussion in 'Freeview & YouView' started by freddyuk, Nov 24, 2004.
  1. freddyuk
    freddyuk
    Sep 27, 2004
    202
    Can anyone advise if it is easy to connect my Relysis with a TV tuner RGA input to my freeview box with RGA input /output and component connections?
    Just connecting the ariel as per normal does not work and there are no scart inputs on the LCD.
    Help out a real dummy please? :lease:
    Freddy
  2. net_team1
    net_team1
    Jan 23, 2004
    34
    Is it the 17" Relisys LCD?
    This has S-video connections, does your freeview box have an s-video connection, or the ability to output s-video through the scart connection?
  3. freddyuk
    freddyuk
    Sep 27, 2004
    202
    Yes it is the 17 inch version. It has S- video input and a scart on the freeview box. Do i need an S-video to scart adapter as the best option as these are about £25??
    Many thanks
    Freddy
  4. net_team1
    net_team1
    Jan 23, 2004
    34
    Check the manual of the freeview box, or look in the setup menu to check if it will output S-Video through the Scart socket, if it will then a scart -> S-video with 2xphono connections will work like this:
    http://www.tvcables.co.uk/cgi-bin/tvcables/SC301.html
    Or this:
    http://www.tvcables.co.uk/cgi-bin/tvcables/AD001.html
    plus s-video & phono cables, if the worst coms to the worst then you could always connect with this adapter via composite (single phono) but this will be the worst picture quality.
    Or
    If the freeview outputs RGB scart only, then you could get a convertor box to change the signal to something else ( Component, S-video, even VGA).
    http://www.js-technology.com/index.php?cPath=22&osCsid=24acf978521bb5c620fb0893be085483
    But this is quite expensive.
    So first check if the freeview box will output s-video via its scart socket.
