Relq200e/avca1d
Discussion in 'Home Cinema Speakers' started by RobsterD, Apr 1, 2001.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Running the above with b&w cdmc and cdm1 se's
    would really like to improve the performance,
    i've set the fronts to large/small but am having trouble integrating the sub into the room/system,any thoughts would be appreciated.
  2. Arthur.S
    Arthur.S
    Rob, There's been a whole raft of posts on this subject. Do a search on the word 'sub'. Also check out the FAQ's on this site. I'm always fiddling with the setup on my subs. Basically, it seems to be better for music to have all your speakers set as 'large', with the subs handling all the LFE. But better for movies to have them set up either as all 'small', with all the LFE going to the subs. Or Centre/surrounds as 'small' with the L & R fronts 'large', the LFE going to fronts & subs.
