Question Reloop RP-2000m
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Bleem100, Apr 1, 2016.
  1. Bleem100
    Bleem100
    Dec 22, 2007
    40
    12
    Bolton, UK
    Any thoughts on this TT - pro's & con's
    Would be grateful as I seem to be going round in circles buying a new TT
  2. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
  3. Bleem100
    Bleem100
    Dec 22, 2007
    40
    12
    Bolton, UK
    Thanks, may give that a miss then. Back to the drawing board.
  4. Member 459099
    Member 459099
    Mar 23, 2010
    11
    Hi Bleem100
    Depends what you're after? The RP-2000M is Reloop's entry level direct drive deck. It's a good deck for bedroom DJs but wouldn't cut it just for Hi-Fi use.
    If you can stretch the budget a bit I would go for Pro-Ject's Essential MKII turntable (£209).
    I hope this helps.
