Relisys rp4205
Discussion in 'Plasma TVs Forum' started by thepacifier, May 7, 2007.
  1. thepacifier
    thepacifier
    Nov 28, 2005
    105
    Dunfermline
    I have:lease: just purchased one of these panels second hand,and am regretting purchase already. The picture is dire to say the least,and i paid £350. Does anyone know if the set is Progressive Scan compatible,and any ideas how the picture can be improved,as in particular,dark scenes on dvd's are attrocious to say the least. Thanks.
  2. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    What's wrong with the picture and how have you got the DVD connected?
    I don't think prog scan is your concern at the moment. It can certainly accept it and like most plasmas is a progressive display but it could be that it's just rubbish at blacks, it could be bad colour processing, it could be that it's setup wrong/badly or it could be that it's a rubbish connection.
    And which DVD player is it?
    It might interest you to know it was £2200 when it came out 3 years ago ;)
  3. thepacifier
    thepacifier
    Nov 28, 2005
    105
    Dunfermline
    Thanks for your reply. Using an lg dvd recorder, however when i select component the picture "Splits" and displays itself on each side of the screen.
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    What wire are you using?
  5. thepacifier
    thepacifier
    Nov 28, 2005
    105
    Dunfermline
    Hi, bog standard philips component to component cables. Dvd player is prog scan compatible,however tv displays warped "Split" picture.
  6. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Strange. Outputting 480p or 576p? (R1 or R2 DVD?)
  7. thepacifier
    thepacifier
    Nov 28, 2005
    105
    Dunfermline
    Perhaps i should have re-phrased the original question- Does anyone know if this set is Progressive Scan enabled?
    Many thanks.
