Relisys RLT1730 RGB Scart?
Discussion in 'LCD & LED LCD TVs' started by neil_gilroy, Aug 12, 2005.
  1. neil_gilroy
    neil_gilroy
    Aug 8, 2005
    96
    Can anyone with this 17" lcd tv screen confirm if the scart is RGB? Im considering this or the Mikomi from Argos. Both are around £250.
    Many thanks,
    Neil
  2. b1g1an
    b1g1an
    Aug 15, 2005
    283
    28
    +47
    Don't even bother looking at the Relisys.
    Just bought a 1730 from Asda which was to replace the Mikomi I've got in which thunderflys have crawled inside the screen and it won't come apart to clear them out.
    Unplugged the Freeview box and put it straight into the 1730........what a load of garbage that is. Picture is very unclear and movement is dreadful, the mikomi just goes a little soft when there is fast movement.
    Put it straight back in the box and will try to get another Mikomi. Can't believe the Relisys gets good reviews as it shows everything that is bad with LCDs with great clarity.
