Relisys RLT1730 Help
Discussion in 'LCD & LED LCD TVs' started by andyrich72, Aug 25, 2005.
  1. andyrich72
    andyrich72
    Just purchased a Relisys RLT1730 and have found the picture quality when connecting a PS2 console is rank.
    Is there anything that can be done to improve the picture or is it a case that this LCD is poor and should be returned and replaced with a better model.
    Any advice on recommended 17" LCD Tv's would be appreciated.
  2. b1g1an
    b1g1an
    Aug 15, 2005
    283
    28
    +47
    It's just crap.
    I got one to replace my Mikomi thinking it should be better from what people had said but it took that to realise just how good the Mikomi is for the money.
  3. WSB
    WSB
    Dec 31, 2004
    354
    +7
    it does take some time to find the right monitor...
    having said that- I've had the Relisys 32" for a few months and find the PQ on my xbox to be good. I did have to play around with the settings though as when I first tried it the picture was too dark.
    not sure what settings the 17" has but have a play and see what you can do with it- then return it(!) :rolleyes:
  4. andyrich72
    andyrich72
    It is crap and found out first hand.
    Yes i had a play and couldnt fix it so took it back.
    Replaced it with the Samsung SM730MW £299 from pc world.
    A vast improvement on the Relisys at everything.
