RELISYS DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by con_dorleone, Nov 11, 2004.
  1. con_dorleone
    con_dorleone
    Oct 21, 2004
    27
    Anyone used the RELISYS RDVR250(D) recorder?
    I'm tempted to get one, mainly due to the price and the excellent input/output connectivity. Is this a good company/model?
    Cheers.
  2. andycat
    andycat
    Nov 7, 2004
    15
    I've thought about this one too, as it seems to have a decoder? Is this correct?
  3. con_dorleone
    con_dorleone
    Oct 21, 2004
    27
    For around £150 I doubt it's got a decoder - but it is a basic machine with what appears to be excellent connections front and rear! I'm trying to find out what the recording/playback quality is like? And how compatible it is with DVD-R-RW, or even +R made on other machines?
    (Also, not sure whether the tuner's NICAM stereo or boring mono!)
  4. con_dorleone
    con_dorleone
    Oct 21, 2004
    27
    Apologies, Andycat - it appears the unit has indeed got a decoder:
    Output Connections:
    S-Video - Mini-Din 4-pin (Rear)
    Composite Video - RCA jack (Rear)
    SCART - 21 pin Euro Connector
    TV Tuner - VHF/UHF, Coaxial 75 ohms
    DVD Component - RCA jack Set (Y Pb Pr / Y Cb Cr) (Rear
    Audio (5.1ch) - RCA jacks (L/R/SL/SR/C/SW) (Rear)
    Digital Audio - Coaxial, Optical
    Input Connections:
    S-Video - Mini-Din 4-pin x2 (Front/Rear)
    Composite Video - RCA jack x2 (1Front/1Rear)
    SCART - 21 pin Euro Connector (Rear)
    DV i-Link - IEEE 1394 4-pin (Front)*
    Audio (L/R) - RCA jack x2 (1Front/1Rear)
    Power Supply - 100~240 V, 50/60 Hz
