RELISYS 17INCH lcd TV ///////£ 249 inc 3 yr warranty
Discussion in 'LCD & LED LCD TVs Forum' started by foxyuk13, Dec 8, 2004.
Tags:
  1. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
  2. faisal_uk
    faisal_uk
    Aug 16, 2004
    98
    +5
    it is poor - i bought one and then sold it.
    i mainly wanted to use it as a pc monitor and the colours looked washed out, the response time wasn't brilliant and just did not look good.
    tried connecting an xbox to it via s-video and it was slightly blurry, and text could not be read easily.
    only tried the tv connection through a portable aerial - and that was ok, but nothing near crt quality.
    so if i was you - i would avoid it
    dvd movies did play well (through my computer) and that was about it.
    it is cheap for all these reasons!
  3. duncs
    duncs
    I bought one of these a while ago. While I would agree with some of the comments made by faisal_uk, overall I am happy with the set.
    The input from a PS2 is a bit blury but it works ok. The blacks are a little grey. The colour response looks ok to me and I don't find the response time a problem. Running my PC through it and it is great.
    Given its cheap price, you need to consider if any of the issues that you may find are worth the saving. I would advise you to get a demo of it and see what you think.
  4. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    just got one....... bt shop do a 14 day money back!!!!!
    been on the relisys website . and richer sounds seems the version has been improved
  5. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I have one too and it`s good for the money. PC input looks great. Tuner is a bit dodgy though
  6. paulockenden
    paulockenden
    Dec 2, 2004
    32
    I have one and it is awful.
