RELinquished
Discussion in 'Home Cinema Building DIY' started by IronGiant, Jun 21, 2003.
  1. IronGiant
    IronGiant
    Jun 7, 2003
    62,155
    Oxford UK
    +39,130
    OK, the build is on. The first stage was to build a jig that would function as the equivelant of Taz's £400,000 cutting machine. So I needed something that would:
    1) cut a straight line
    2) cut it in the right place
    I came up with this. It should cut straight with a circular saw trapped betwen the runners, and if I line that cut exactly on the line I want to cut I should be home and dry.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Looking good mate!
    :smashin:
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    How dare you cut up a piece of STEN :nono: - that stuff's the best value shelving ever.
    How are you going to make sure you get 90 degree cuts?
  4. IronGiant
    IronGiant
    Jun 7, 2003
    62,155
    Oxford UK
    +39,130
    It was surplus to requirements :)
    90 degrees will come from careful measurement and a set square (I hope)
    Just going to do it now
  5. IronGiant
    IronGiant
    Jun 7, 2003
    62,155
    Oxford UK
    +39,130
    Well the jig was a great idea, but the saw snagged and twisted while running up the MDF and my first cut was 3mm out at one end.
    So I used the square sides of that piece to clamp it 96mm downstream of wherever I wanted my cuts (the right spacing for my saw), all the while using a 300mm set square on everything to keep everything true and just have a guide on the one side.
    Seems to have worked really well. (So I cut up that STEN for nothing Rrichard)
    I messed up the first speaker hole because I hadn't properly figured out the router + hole cutting attachment, but fortunately I did the smaller one first, so was able to wedge in another bit of board to get a new centre point and cut it bigger.
    This is a "balance" fit, (hence no central brace yet), no joints at all, it's held together by gravity, which makes me pretty happy it's all going to go together properly.
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Looking good.
  7. IronGiant
    IronGiant
    Jun 7, 2003
    62,155
    Oxford UK
    +39,130
    After previous attempts to put together a project in MDF, measured, drawn by ruler, cut with a circular saw, but freehand, I'm pretty impressed by what I achieved by this method.
    Everything is perfectly straight and square and my worst tolerance is that the two front panels may be 1 mm too short. Given they're front mounted to the rest of the box I don't think any one will notice if I leave that underneath where it won't show ;)
    I blame the timber merchant whose tolerance on the long cuts was off by about 1mm :D
    I could try and sand three sides and the baffle down by 1mm, but it's easier to add a strip of veneer to the bottom of the front panel, should I feel it's necessary.
    Dave
