REL T1 .1 LFE Connection
Discussion in 'Subwoofers' started by Ranglo, Jun 2, 2008.
  1. Ranglo
    Ranglo
    Feb 24, 2007
    26
    Does anyone know if the crossover on the .1 LFE connection for a Rel T1 is separate from the the HI/LOW crossover knob. Essentially do the settings on the processor control the crossover when watching a movie?
  2. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,252
    They are independent of each other. When the low level/LFE input is set to bypass, the subs crossover will then only control the high level/speaker input.
    Incidentally this is exactly the same as the XLS-300/PR which is worth a look as it is a direct equivalent to the T-1, only less expensive. Both are good compact subs though.
    Russell
  3. Ranglo
    Ranglo
    Feb 24, 2007
    26
    Cheers Russell,
    However there is no such control to set the LFE to bypass, there is just the .1LFE input and a single crossover for the internal crossover. Are you certain they are indepentant of each other? Further detail would greatly be appreciated.
  4. hoppaz
    hoppaz
    Oct 1, 2005
    1,916
    +225
    I think Russ is saying if the sub isn't receiving an LFE via the phono input (i.e watching movies in DD or DTS) then it runs only using the high input and vice versa.
  5. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,252
    It could be that the input labelled 'LFE' simply has no crossover. I can't believe REL would delete one of their major USPs.
    Without wishing to sound sarcastic, what does the manual say? I've tried downloading it, but the link isn't working for me.
    Russell
  6. Ranglo
    Ranglo
    Feb 24, 2007
    26
    Yeah I've downloaded it but its still not clear to me exactly how to set it up. Oh well not to worry, thanks for your help anyway
  7. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    Managed to get the manual form here.
    From what I understood, you have 2 low-level inputs, one labelled "low level" and another "lfe". The "hi level / Neutrik" and "low level" share a common gain and the single crossover on the sub. The "LFE" input only has a gain knob and is not crossover filtered.
    Hope that helps.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    That is correct.
  9. Ranglo
    Ranglo
    Feb 24, 2007
    26
    Cheers for the help, just looked through the manual in more detail and agree
