REL Strats 5 not working
Discussion in 'Subwoofers' started by SteveRSF, Aug 10, 2004.
  1. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Hi peeps............connected the new sub by the LFE input from my Yamaha A1..but it just hums.......it's as if there's no signal going through
    will ring the shop tomorrow but any ideas?
    thanks in advance!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Have you told your Yamaha that you have a subwoofer. If you are just replacing one sub with another it should work straight from the box
  3. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Yes m8 replacing a yamaha sub with the rel
  4. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Took it back to the shop today and it's fooked ,so REL are building a new one!
    Not bad for an £800 sub! :zonked:
  5. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Got my new one today and it is totally awesome!
    must have just been one of those things with the faulty one.........and yes it had to be me that had it!
    But i can't praise it enough it is suberb! :smashin:
