REL Strata III vs Q400E
Discussion in 'Subwoofers' started by t-force, Apr 25, 2002.
  1. t-force
    t-force
    May 2, 2001
    1,859
    Southampton, UK
    +150
    Does anyone know how these 2 subs compare against each other. What are the pros and cons of each, and what environments is one better for than the other?
    Cheers,
    T
  2. eddiea
    eddiea
    I currently have the Rel Stata III but tested most of the range before I bought this.
    The 400e is a fine sub but IMO is too powerful for my small listening room very good on LF and High level for music, goes a bit lower than the Strata you realy feel the bass.
    My Strata is also very good on LF and High level, but suits my room better, I love it.
    You realy need to to test them at home.
    Happy testing
    Eddie
