Rel Storm Setup info needed.
Discussion in 'Subwoofers' started by Mark Ward, Jan 16, 2004.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I just bought a Rel Storm on the forums and need some info for setting it up.
    Does anyone have a link to any info that may help me? I need to know the "Fine" and "Course" settings for using in a system with an 80hz Crossover from the amp. I want to be sure the Rel isn't filtering out material below 80 hz that I have re-directed to it by setting speakers to small, but above whatever the current Rel settings may be.
    Cheers,
    Mark.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    There's a good setup guide on the REL website that explains it far better than trying to do it here!....well worth a look.
    www.rel.net
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I had a browse on their site prior to posting, infact I used to have a Strata II a while ago and I had a chart with what the various combinations of dials set the crossovers at.
    This is the info I need, to to do with the positions on the Course & Smooth dials which determine the sub's internal frequency filter.
    I no longer have this info and couldn't locate it on the Rel site. I did ring them and the helpful lady did forward me some info, but none to do with the various dial settings and what they set the filter at.
    Essentially I want to disable the internal filters, but full info would be useful :)
    Thanks for any help,
    Mark.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    PM me your email address and I will forward you a copy that I have on disc
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Right...I see what you're after...my apologies...from my understanding of their setups,using the LFE input effectively by passes the internal filter network,and the following lines from the site seem to bear that out....
    "Please note that when using the LFE input (Position 2 of the mode switch), the Sub-Bass System’s filter controls are bypassed,"
    For what it's worth,I currently have a Q201,and use it via the LFE input only,since everything else is done via the AV processor ....hope that's a bit more helpful than my first post!
  6. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Alex
    There lies the problem, I have no "Mode" switch on a Rel Storm I, infact I didn't on my Strata II either. The Dials definitely do affect the low level input however, I've been twiddling. It apperas that IanJ may well have the info I'm after, Thanks for trying.
    Ian
    Will PM you now, thanks!:)
    Mark.
  7. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    IanJ is by far the best man for the job,and knows a lot more about the older REL's and subs in general than I do,so you should have a good deal more luck there!...hope it all sorts out ok.
  8. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    48
    Leicester
    +56
    Ian helped me out with this info when I was selling my Storm(covered the whole ST range) and I've since found the electronic copy of the Storm MK1 Manual too. If you send me your email address I'll forward it to you.
  9. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    All sorted thanks to document forwarded by Ian J:)
    Cheers everyone (Esp. Ian)
    Mark.
  10. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Oops! Missed this when I logged back on to post I'm sorted. Yes please, that would be most helpful too.
    Will PM you my email address now,
    Cheers,
    Mark.
  11. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    I've a question to as a soon to be acquiring a Storm V1 too - if I use the "high level connection" ie Neutrik on Storm to the 3 speaker connections, Red/Black to Right speaker out on amp and Yellow to left speaker out - right I understand all of that - but then where do you the plug in your speaker cable for the normal speakers. I'm presuming you just put say the subwoofer high level termination + the appropriate speaker cable end in the same connection ?
    Doesn't say anything about it in the manual !
    Thanks,
    Mark.
  12. 337GUS
    337GUS
    Nov 1, 2000
    751
    NE Scotland
    +38
    You just wire them into the same banana plug or speaker terminal.
    Gus
  13. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Super thanks Gus - I thought that would be the case - but as the manual didn't say anthing I wasn't sure. On my Yamaha sub you see on the sub itself is the Speaker in connections - but then the Speaker out connections to connect to the Speakers - suppose just for convienience.
    Mark.
