REL Storm III questions
Discussion in 'Subwoofers' started by russraff, Dec 8, 2001.
  1. russraff
    russraff
    Aug 1, 2000
    2,458
    Newcastle
    +80
    Hi there,
    I am the proud owner of a Storm III. Problem is, the unit was an ex-display one and didn't come with any instruction manuals. Now, I can figure out most of the control panel, bar the "Mode" switch. I seem to remember from a previous REL thread that one of the modes (either LFE or LINE) bypasses the sub's internal crossover and uses the amps' crossover instead. The other does use the subs crossover, but only for one of the inputs. Or something.
    I am very confused.
    At the moment I have the amp (Denon A10SE, also a new purchase) setup with all speakers to small (though this is because I am not too sure on the sub settings - I would prefer the fronts to be large) and the sub out going to the 0db input on the Storm. I have the Storms crossover to max.
    Is this right, should the fronts (capable down to 40hz) really be large with such a capable sub, what the hell is the mode switch?
    Someone help!
    Thanks in advance - Russell
  2. Timmie Boy
    Timmie Boy
    Jul 16, 2000
    54
    You have looked on the REL website?
    The manuals are there
    http://rel.net/
  3. russraff
    russraff
    Aug 1, 2000
    2,458
    Newcastle
    +80
    Sorry, must have missed it the first time.
    Thanks Russell
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,682
    The REL website is about to be completely revamped with new instruction manuals.
    Also check out the FAQ here for sub connection information.
  5. Lowrider
    Lowrider
    Select position 2, it bypasses the internal crossover for the low level input, so it will use the amp´s, but it still uses it for high, if you decide to use your speakers as large with the supplied connectors...
