Rel Storm II clone
Discussion in 'Subwoofers' started by asdonk, Sep 11, 2005.
  1. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    hello I am new to this forum and have a question about a Volt B250.9 woofer
    which I bought last week, it is used in the Rel Storm II subwoofer
    I want to build a clone off this subwoofer and wil use a BK electronics BSBP200 plate amp , the enclosure has to 40 litres reflex loaded
    as Ral uses the ARM loaded system, I want to know what dimensions the bss reflex pipe has to have
    who can help me out?
  2. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
    The Subwoofer DIY Page:
    http://www.diysubwoofers.org/
    You may find the information available here useful.
    "ARM" may be rather more difficult to achieve. I would suggest that you find a matching conventional reflex enclosure for your driver as a starting point.
    Always remember that many manufacturers (buying in bulk) can have drivers built for them to exact specs that the standard privately-bought driver may not offer.
    If you are feeling adventurous you could try a bandpass subwoofer using your driver. A guidebook " The coupled Cavity Handbook" by David Purton is available from Falcon Acoustics for about a fiver.
    http://www.google.dk/url?sa=t&ct=re...on-acoustics.co.uk/&ei=iYAkQ4OdH5uUiAKQ2ZWHAw
    Nimby
  3. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    a design at the side off wilmslow audio puts the B250.8 in a 40 ltr bassreflex enclosure, but the length and size off the pipe are not given
  4. tahirti3
    tahirti3
    Sep 18, 2002
    1,486
    48
    +25
    i was told a few years back that the rel drivers are modified for them by volt.normally by changes to mass of cone.chances are the storm measurements wont be right for the standard volt driver.
  5. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +670
    "ARM" which probably means Acoustic Resistive Matrix probably modifies the bass response of the driver to such an extent that copying REL box dimensions will be a useless exercise anyway. :thumbsdow
    You need a normal reflex design using your Volt driver.
    There's a free reflex box designer here:
    http://www.audiogrid.com/audio/
    Nimby
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    and I don't think ARM was on the Storm either, it was for the better models only. There we two volt drivers that could be used on the Storm the standard one or the better one as fitted on the Stentor etc
  7. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    The Stadium was/is the first in the Rel range to use ARM IIRC.
  8. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    so with the 40 ltr enclosure and no ARM it must be possible to make a great sub, I also have a plate amp with a ajustable bassboost at 30 hz
    with a range off 0 to +6db, phase can be ajusted between 0 and 270 degrees
    the Volt woofer has B250.9 and is not the same as the B250.8
    but they will have a lot in common
    I also have the possibilty to measure the T&S parametres
    maybe is that the way to go
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Forget the REL clone and just make a great DIY sub.
  10. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    the plan was building a sub with the Volt woofer, and together with the thommessen plate amp it has bcome a great sub
    with a little boost at 30 hz it gives a deep and nice bass
    some ajusting to the phase made also a difference and so far I 'mhappy with the results
    I have put the sub on a marble plate and this was also a big difference
    the crossover is set at 40 hz, with the front speakers using a scanspeak
    sliced paper woofer going down to 40 hz :)
  11. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    after bying a rel storm I had the possibilty to compare the 2 subs side by side
    :devil:
    the clone could reach even deeper down because off the bassboost
    the 2 drivers are both B250.9 Volt woofers, the leght off the reflx port is about 51 cm and the internal volume 38,8 litres
    the DIY enclosure has the same dimensions
  12. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +670
    Well done!
    Where are the pictures?
    What do we want?
    We want pictures!
    When do we want them?
    We want them now! ;)
    :arty:
  13. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    as above post....heh
    btw nimby, dont suppose u wanna buy my REL Quake i put up in the classifieds forum? if so post a message there....heheh
    and no you cant buy it to put in a dolls house ;-)
  14. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +670
    Make a meaningful sentence using the words:
    Dead, over, body & my. :devil:
    I think we're drifting from the subject. ;)
  15. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    do i need to keep the commas and ampersand?...cant make a sentence that way...heh
    i'd love to see the pics of this sub tho, would be cool to see a home made effort :)
    even better to hear it...heh
    bit difficult tho using the web...unless you got a videocam with a good mic...lol
