REL Storm I Vs REL Storm III
Discussion in 'Subwoofers' started by monotone, Nov 10, 2003.
  1. monotone
    monotone
    Opinions needed... how much improvement from the Storm I to Storm III?
    Worth paying £480 for a second hand Storm I?
    Cheers!
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    I've only owned the Storm III out of the of these two subs but I have picked up comments from others on these forums about both these subs.
    It seem the difference is only slight. With the Storm III having more power but the difference it makes is minimal.
    I would however say that £480 seems a bit over the odds unless its an absolutely immaculate example with hardly any use, I'd suggest around £400-450.
  3. monotone
    monotone
    Power relates to loudness and not how low/deep it could go right?
    As I enjoyed the Storm III's performance (when I demo-ed awhile back), am after a sub with similar lows (loudness is not a big issue as I live in an apartment). The Storm III RRP£1400 (but could get it brand new for around £1,200).
  4. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    Ah right your in Oz.
    Well they Storm III retails over here at £800 for the standard finish and £900 for the veneers.
    I'd go for the Storm I if I were you. There is little between the two. And the Storm is a competent subwoofer.
    I think you'd be pleased.
    With regards to the power difference between the two... it only really makes a difference at higher volumes, where more power mean more control.
    You really need somebody who has owned both for them to comment accurately.
    I can say that the Storm I is good however.
  5. monotone
    monotone
    Aargh!!! £900 for brand new venner finish!!!
  6. lmn8r
    lmn8r
    Does the Storm I have both the high level and low level inputs and separate volume controls for each?
    Thanks.
  7. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    Yes it does.
  8. DucatiEVO
    DucatiEVO
    I notice on the REL high level input cable that it has the wires black, red and yellow? Assume you get the + and - for the signal but never seen a yellow as well, where does it go...
  9. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    Its goes to negative on the opposite speaker channel.
    This is the grounding point basically, giving you a balanced input.
  10. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    480 pounds for 2nd hand storm I!? You should be able to buy 2 of them for that much!
  11. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    He's in Oz, there's a premium to pay over there!
    But your right, if it was over here you'd be lucky to get £250-300 for an old sub like that.
  12. monotone
    monotone
    Hey there... bought my second hand Storm!
    Am really happy with it... still trying to adjust it properly so it would fit into my system... using Low Level connection at the moment, will High Level improves its performance much by going through the power amp?
    Yeah... I know REL is cheaper in UK... am just looking for a second hand at the moment (Brand new pretty off my budget at the moment :-()
  13. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    You total tube. Are you trying to blow up this guys amp or sub? The red cable goes to to the positive terminal of the right channel on the amp, the yellow cable goes to the positive terminal of the left channel and the black goes to either negative terminal, but not both.
    If you need more specifics then download the REL St manual from the link below.
    REL ST series manual
  14. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    Monotone - I've got a Storm III, which I love.
    I got it from Ian J, who I believe has owned both models (the I and the III). He said that he couldn't actually tell any difference between the two.
    The III has more input options and a nicer finish, but sonically I don't think there's much in it!
  15. quadophile
    quadophile
    Sep 6, 2003
    78
    11
    +4
    You should try and setup your Storm with guidance from REL site the REL/Sumiko setup works great and also check the following thread for some more information which you may find useful nonetheless.
    REL STRATA III
