REL ST set up guide
Discussion in 'Subwoofers' started by clived, Dec 23, 2002.
  1. clived
    clived
    Jan 4, 2002
    265
    Hertfordshire
    +5
    As you may have seen in my other post, I've currently got a REL Strata III on loan. Unfortunately, the shop has lost the instructions....
    I do have the generic setting up guide that can be found on the REL site, but I could really do with a short guide to what the controls do exactly, rather than my best guesses - the mode switch, what the letters and numbers on the filter knob represents, if I should be using the +12dB input and reduce the amp output or not (I'm currently assuming "not").
    Of course, in anyone had a scanned copy of the instructions, that would be ideal!
    Thanks, Clive
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I'm only around for an hour than away this week but if you PM me your email address I will email you a copy in Word format.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I'm not sure that the manual that I emailed you had details of the mode selector switch.
    1 Line input in phase
    2 LFE input in phase
    3 Line input out of phase
    4 LFE input out of phase
    The letters and numbers combine to set crossover frequencies .
    I have my amp set to output less that 80Hz to the sub and have the sub setting on D4 (83Hz)
