Rel Quake sub
Discussion in 'Home Cinema Speakers' started by LearningCurve, Aug 17, 2004.
  1. LearningCurve
    LearningCurve
    Aug 17, 2004
    Hello all,
    I'm quite new to this forum but been browsing it for quite a while now. Looking for some advice and hints on the best speaker setup and subs to get for the money.
    I'm currently looking at B&W DM 600 fronts and rear, LCR60 (centre) and REL Quake for the sub. Choices really were narrowed down for space and quality and the best I can get for the budget (I hope) ;) .
    My question is, does anyone have a similar or something similar to this setup? And your thoughts? :lease: What's it like on movies?
    I have a YAMAHA RXV640 (hopefuly enough) to run these babies :D
    I'm going to be demo-ing these guys this weekend and hopefully will make a decision then.
    Any help would be much appreciated.
    LearningCurve :D
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I'd seriously consider the BK XLS200 sub and the Mordaunt Short 309 sub. If you do a search you'll find plenty of information on them including a direct comparison that a few of us did!
    Otherwise I'm not familiar with your choice of equipment but the magazines seem to like it :)
  3. Roohster
    Roohster
    Jul 1, 2004
    4,116
    7
    Derbyshire
    +4,467
    Naaaaaaaaah....
    go with a Rel Quake!
    Unbelieveable grunt from such a tiny sub.
    Works well with movies and music.
  4. Davej50
    Davej50
    Not completely familiar with that setup but have a set of 5 B&W VM1's with a Rel Quake and am more than pleased with them and they weren't too expensive (£125 each but got a bit of a deal so a bit less than that. I think I got the Rel for about £300ish). The B&W's are fixed on the walls with the supplied brackets and are very discrete - even my wife was happy with them!
    I wasn't too happy when I originally bought it all as the sub didn't seem to be performing very well, but recently got a curved sofa and put the Rel behind that (in the corner) and 'Oh my god!' what a difference. I can't believe how good it sounds - 100 times better than when it was standing in a corner 'out in the open'...It really pays to move it around and experiment.
    Hope this helps,
    Dave.
