Rel Q50
Discussion in 'Subwoofers' started by smallangryboy, May 5, 2003.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I'm trying to get my hands on a Rel Q50 sub, after much recommendation. The only problem is that this has been discontinued, and I can't seem to find one for love nor money, new or second hand - anyone have any ideas where I could look ?
    Thanks in advance
    Ad
  2. puddleduck
    puddleduck
    Jan 24, 2003
    1,853
    48
    Lake District, near as dammit
    +59
    Try Loot
    I got the one of the last Q50s that REL made, and its a top subwoofer.
    Expect to pay around £200-£250 second hand.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Or here
    There was one in the classifieds of this forum but that was sold yesterday.
  4. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    They go on eBay fairly regularly.
  5. nathan_silly
    nathan_silly
    You could look for a Rel Q100E instead, basically the same but with 100W amp and a grille (Q50 has no grille)
  6. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    There is a Q 150e sub up for grabs - how is this in comparison to the Q50 ?
  7. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    The Q50 and Q100 are much better than the Q150.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It rates poorly in comparison so don't buy in haste and repent at leisure. Alternatives to waiting are a Velodyne CHT-10 in the forum Power Buy section at £325 or a 300watt sub from the company that actually made the Q100 on behalf of REL at £280 available from here and click on bargain corner
  9. jonnyv
    jonnyv
    Mar 31, 2002
    2,265
    48
    +49
    smallangryboy, theres a few on ebay right now, i just won an auction for one for £250, im happy !
  10. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Thanks gentlemen , sage advice... hopefully managed to get my hands on a secondhand Q50 :D
  11. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Have just seen an advert for a very reasonably priced Rel Storm II.
    How does this compare, apart from looking like the monolith out of 2001...
  12. nathan_silly
    nathan_silly
    Alot better than the Q series (I have a Storm) goes louder & lower, the Q struggles and runs out of excursion quite easily (with certain frequencies)
  13. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    My room is approximately 12' x 14', would the Storm be too large for this area, both physically and sonically, would the Q50 better suit a diminutive room ? Or doesn't size matter after all :)
  14. nathan_silly
    nathan_silly
    My room is 3.5M x 2.5M. I think my Storm isn't enough- for AV like the sub loud & low.
    You can never go "too big" cos you'll just have the sub lower- a better sub will sound better anyway at the same volume (plus louder & lower of course)
    My mate has the Rel Q100E, compared the Storm v Q100E (similar to the Q50). One problem with the Q100E is on Startship Troopers Whiskey outpost scene the 100E parps even at lowish volume, I don't know why. The sub is not faulty. Also has problems with digital-sourced audio (ie Toy Story II intro, Titan AE) Most other DVD's are fine.
  15. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Just out of curiosity, what are the dimensions of the Storm / Q50 ?
    I guess sonically there is no contest, unfortunately my other half has a significant input into the aesthetics of our house. Large black objects that look like they come from the bridge of the Enterprise are frowned upon - hence the tradeoff !
  16. nathan_silly
    nathan_silly
    Q50 I think is 45cm cubed.
    Storm is 42 wide, 30 high, 65 high (cm)
    The Storm takes up less floor space than the Q50/Q100, it's just higher.
