Rel Q400
Discussion in 'Subwoofers' started by EN, Aug 17, 2004.
  1. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
    Can anyone tell what is the difference between REL Q400 and Q401?
    Thanx
  2. recruit
    recruit
    Hi EN,
    I don't think there is any difference but i do remember hearing that it might have been released as 401 in america not 100% sure on that though
    here is a link to REL page...they both have the same specs.
    www.rel.net/index2.htm
    John :)
  3. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    In the case of the Q200e and the Q210e the only difference was the inclusion of a grille on the 201. The Q200 just had the driver showing at the front with no coverage.
    Could it be the same for the 400 series?
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    The 401 is a later version of the 400.
    It's exactly the same apart from the grill.
    If you are thinking of buying one I'm sure there is better value for money to be had.
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    If your set on buying the q400e there is one for sale in rosewood for £649 at www.moorgate.demon.co.uk. Russraff off the forums has the q400e and seems very pleased with its performance given its size.
    Cheers Gonzo. :)
    PS click on special offers.
  6. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    OOPS :blush:
    Just noticed your in bulgaria.Well someone else might want one.
    Cheers Gonzo.
