REL Q201E vs B&W ASW-750
Discussion in 'Subwoofers' started by smithers, May 8, 2005.
  1. smithers
    smithers
    I'm shopping for a new sub I've been hearing good things about REL but I without having heard one I am a bit in the dark.
    I'm from Canada and unfortunately for us north american's the only available REL's are listed here http://www.sumikoaudio.net/rel/index.htm.
    The only sub listed on the link above that is in the same price bracket I had in mind $2000-2500 CDN (or ~37 pounds :p) is the Q201E, but I don't see how the included 250 watt amp and 10" driver could ever compare in SPL to the 12" driver and 1000watt amplifier found on the B&W.
    I should stress that the musicality of the sub I choose is a little more important I also want it to kick me in the pants whenever I pop in a DVD.
    What do you guys think?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Don't get too hung up on paper specs as the quality of the components used are much more important than the size.
    There is more to a subwoofer than sheer SPL as it is pointless having a subwoofer that can reproduce low bass at loud levels if all you are listening to is distortion due to poor quality components
    The REL Q200 isn't a bad sub and should certainly be considered if music is a priority as not all can match the nimbleness of a REL on complex bass notes. I haven't heard the B&W offering but it certainly has a few fans on this forum.
  3. russraff
    russraff
    Aug 1, 2000
    2,313
    Newcastle
    +51
    The simple answer is it can't. I used to own a Q200/Q201 and have heard the B&W750 a few times. Let me say that the B&W750 is so much better than a Q200 it doesn't bear thinking about. In fact it's a bare faced cheek that the Q200 is even in the same price bracket of the 750. The Q400 is a good sub, and much better than the Q200, but I would still rate a 750 over all of them. In fact, the only REL sub that I can think of that comes close (that I have heard) is a Storm V. Even then it was some time between auditions of 750 and Storm V and I wouldn't be surprised if the B&W won out on all round performance. Saying that it doesn't look like the lower range ST subs are available over there and, even if they were, the Storm V would probably be much more expensive.
    Go listen to the B&W, you won't be dissapointed.
    Russell
  4. SKA.face
    SKA.face
    I had a REL strata,never got on with it,tuneless,just didn't do anything for me,found a older B&W800 sub,blew RELs away,not the exact answer toyour question,but i'd go for the B&W.
  5. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    Smithers have a look at the New Paradigm Servo 15
    http://www.paradigm.com/Website/SiteReferenceProduct/RModels/Servo/ServoSeries.html
    I'm not sure how much the New Servo 15 goes for in Canada, but try to get demo as the old servo 15 is a great sub and the new model seems to have some nice upgrades 1200 watts RMS‡ (20–150 Hz @ <0.1% THD),
    4500 watts Peak‡‡ ;)
  6. SBanga
    SBanga
    Mar 23, 2005
    2,011
    Leeds, Yorksha
    +267
    Don't you just WISH Richer Sounds would start importing these new ones and selling them for the £399 of the old one?! :lease:
  7. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    I've owned a Q201e prior to my current SVS,and tried out a number of subs when changing from the REL,including the B&W.
    Frankly,I'd have to agree with russraff in saying that there isnt any real comparison between them,although the REL is pretty decent on music.
    In terms of pretty much every value however,the B&W is,to my ears anyway,a much better sub,but you can also see which one actually made it to my living room.
  8. smithers
    smithers
    Yeah I plan on demoing that B&W next week, I just wanted to hear some opinions regarding the REL I don't think they are sold anywhere nearby anyway.
  9. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    In terms of pretty much every value however,the B&W is,to my ears anyway,a much better sub,but you can also see which one actually made it to my living room.[/QUOTE]
    Hi Alex
    When i couldnt get the svs pb12-ultra-2 to work in my room i did think about getting the asw750 instead of importing another sub, seems i made the right decision getting the pc-ultra.
    Cheers Gonzo. :)
