Rel Q200e
Discussion in 'Subwoofers' started by spenceruk, Feb 26, 2001.
  1. spenceruk
    spenceruk
    Can anyone help me get the best out of this sub? I have the Denon AVR-3300 Receiver together with B&W CC6 Centre and B&W DM601's all round. I've got the connections all sussed (I think!) but the manual is not very informative on actual set-up! This is my first sub so not too technical please!!!
  2. Big Jim
    Big Jim
    This has been discussed at length before, so if you look back through the forum you will find more detailed stuff.
    The simplest setup seems to be as follows:
    Connect the sub to the amp with a phono cable.
    Set the amp up correctly using its setup procedure, with the speakers set to SMALL (this will take the lowish bass that they don't do very well and send it to the sub) and the sub present.
    On the sub set the crossover to max and adjust the volume to suit (I think using test tones and stuff, so the sub ends up sounding consistent with the rest of the speakers)
    Hope that is right - I don't actually have a sub, so with a bit of luck everyone else will corrrect all the glaring mistakes I have undoubtably made...
    Jim
