REL Q150E Mk II settings for movies
Discussion in 'Subwoofers' started by banyantree, Dec 9, 2004.
  1. banyantree
    banyantree
    Sep 8, 2004
    170
    singapore
    +3
    Can anybody tell me the correct setting for a subwoofer on the Pioneer Ax5i-G?
    I have an REL Q150E Mk II connected on high & low settings.
    When doing the automatic speaker callibration the subwoofer is set at -10db.
    The other speakers are set at 10db.
    I have manually set the sub at 5db with the volume control on the sub at about 1/4. This gives me the best sound when watching movies. Should I be setting this higher? or should i put it back to -10db and crank up the sub volume?
    any suggestions greatly appreciated.
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    Banyantree
    Does the Pioneer allow you to choose between Large or Small main speakers, or to select the cut-off point for the mains?
  3. banyantree
    banyantree
    Sep 8, 2004
    170
    singapore
    +3
    Yes it does.
    The speakers are all set to SMALL. and the amp was automatically callibrated so I can manually adjust the crossover points.
  4. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    +225
    Banyantree
    Have you tried disconnecting the speakers and just listen to the sub with music and movies? You may be surprised at what the sub outputs on its own.
    I have a REL Quake with my TAG gear and to set the sub I used an SPL meter as I haven't yet upgraded to the DP version with the room correction software.
    I also scrolled through the various sound options starting with straight 2 channel and made adjuestments till I thought the sub sounded right
