rel q150
Discussion in 'Subwoofers' started by Brox, May 11, 2002.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Do these appear secondhand very often ? and what price would they typically go for. Not sure wether to wait, or get something else or buy new.
    Does anyone know where you can get a deal on them, cheapest i've seen is £450.
    Would it be better than the kef 30b?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    I've never seen one second hand in this forum and in view of the number of problem 150s I would be very suspicious.
    Why not have a look at the REL Q50 which you may feel is a step down but you could well be pleasantly surprised. Hifi Confidential are selling them for £299.
    Second hand Q100 is also another good bet and these tend to go for £300 in top condition but are as rare as hen's teeth.
    Bigger in size and very capable are the REL Storm and Strata range which are much more than your budget new but available second hand at reasonable prices
  3. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Thanks for your reply, i'm limited for space unfortunately other wise I would go for the Q50. Have they still not sorted the problems out with the rel?
  4. stranger
    stranger
    have you thought of two paradigm pdr 10s or even four?. a real bargain @ £120.00 each small and quite potent when set up correctly-just a thought.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    I think that if Brox had a problem fitting in a Q50 I don't see how he can cope with four Paradigms.
    Have a look at the MJ Acoustics Pro 50 at £299. This has received five stars in What Hifi and another mag (forgotten which)
  6. stranger
    stranger
    ian, the reference to four was a tongue in cheek price analogy, two would fit in and be a reasonable stop gap while waiting for s/h q50s or similar. the 10s would always sell later and was only a suggestion, ken;)
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    Might work if they are stackable
  8. stranger
    stranger
    they are with the ubiquitous blue tack between them.
