Rel Q150. Can it fire into a wall?
Discussion in 'Subwoofers' started by Jon Weaver, Nov 26, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I can only put my sub in a corner.
    From what I can tell, the Rel Q150, has the driver on one side and the controls on the opposite face.
    If I am to be able to get at the controls, it will mean pointing the driver into a wall...
    Is this OK?
    In the ideal world, how/where would you locate a Q150?
  2. Lowrider
    Lowrider
    It will probably sound better, tighter, some distance from the wall, so you can still reach the controls, I have my Strata 40 cms away.
    I wouldn´t put the woofer side against the wall...
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Unfortunately very few of us live in the perfect home cinema house and needs sometimes must.
    I have the original Q Bass which has in the past been placed in a corner and is currently next to a wall ( driver to the wall).
    There seems to be enough adjustments to play with to compensate for any placement shortcomings and mine certainly doesn't boom.
    Ian
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    +739
    Unfortuantly, I have no choice.. Its either in a corner, or not at all..
    I guess I could turn it round so that the controls are against the wall and the speaker is firing into open space...
    Once the controls are set, I guess that you don't need to make adjustements that often..
  5. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,366
    3
    +8,837
    Just be prepared to spend a lot of time getting those controls set just right. It takes a lot of time to get right, but is well worth it. Also according to Rel it should not cause any problems firing it at the wall.
