quicky here..........how can i connect the rel to a yamaha amp do i need to use a splitter cable?or can i use that neutrik lead thing that comes with it?
thanks... i did actualy have to use a splitter for my velodyne vx10 for the left and right socket on the sub to the amp....how come i can get away with just using either the red or white on the rel? i presume its a mono single from a sub anyway?
Yes, subs are only mono. The velodyne should also work fine without a splitter. I have known some sub manufacturers reccommend using a splitter, but the only gains to be had are usually allowing a slightly greater signal into the sub. This is mainly useful if you have a problem with auto on/off and the double inputs allow the sub to sense the signal easier.
the main reason i used the splitter on the velodyne was down to the problem it had sesing the signal......dont expect the rel to give me the same problem[ well i hope not]
