Rel Q100E used to use spikes....
Discussion in 'Subwoofers' started by jonnyv, May 19, 2004.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,149
    48
    +41
    I have an rel Q100e subwoofer and use spikes into my carpet,im moving to a house with wooden flooring and i phoned rel yesterday for some 'feet' for the sub.
    An envelope arrived today from rel, fast service !
    I opened the envelope and inside were 4 black plastic screws, surely this cant be the proper item for such a high end sub ?!
  2. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +81
    My rel q150e had a choice between spikes and 4 plastic screws that did the same job in a kinder to floors sort of way.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    You could put some coins or something less pointy beneath the metal spikes.
  4. stevegreen
    stevegreen
    May 14, 2001
    8,727
    in my Hymer
    +984
    My Q200e has spikes fitted which in turn sit on four seperate 20p coins. I have a wooden floor and this stops it getting damaged. (I am thinking of upgrading to four 50p coins but i just know at some point I shall then want to use £1 coins and then eventually move onto £2 coins.......upgraditis :laugh: )
    Don't know about the plastic screws but i wouldn't say they are the best thing, I would have thought rubber would have been better :confused: Still, as long as they can be adjusted to stop the thing rocking about thats the main thing.
