REL Q100E or Velodyne Deco sub - which one is better?
Discussion in 'Subwoofers' started by bbanduser, Sep 9, 2004.
  1. bbanduser
    bbanduser
    Nov 22, 2002
    1,893
    38
    Watford
    +3
    Hi guys,
    I have a Rel Q100E and am considering the purchase of a Velodyne Deco sub (which I have heard is the same spec as the SPL 800 sub in a different cabinet). Would this be an upgrade. I have heard that it is a really good one, but still I thought I would ask some of you knowledgeable guys here.
    What's your opinion?
  2. bbanduser
    bbanduser
    Nov 22, 2002
    1,893
    38
    Watford
    +3
    Surely someone ust know about these 2 subs...
  3. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,290
    +57
    I used to have the REL Q100e but it was running out of power, so I upgraded to a Velodyne CHT15 (300 watt amplifier) and i'm very pleased with it. Don't know anything about the Deco sub though.
    I suppose it depends how hard you will be running the sub, because if (like me) you play your films quite loud I don't think the REL will be good enough.
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    My take on it would be that the Q100 will play deeper whilst the Deco would play cleaner but not go so deep. All depends upon what you want really - I wouldn't necessarily see the Deco as an upgrade.
    Matt.
  5. Grimley
    Grimley
    Sep 19, 2003
    970
    4
    2
    47
    Deepest, Darkest Essex, so BEWARE!
    +161
    I have a Deco sub & I'm very pleased with it. (killed my old MJ pro 50 for bass output) Don't think it would be suited in a large room though.....
