Rel Q100e buzzing noise
Discussion in 'Subwoofers' started by mortonman, Aug 25, 2003.
  1. mortonman
    mortonman
    Help,
    I have a faint buzzing noise from my Rel Q100e, it is not the subwoofer cable as it is still there if I remove it. It comes off and on when I switch power off and on,
    Any suggestions ?
    Matt
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,925
    2
    167
    Birmingham, UK
    +9,660
    I recall there being several threads on this topic.
    Try doing a search.
    There's usually a very faint hum, but if it's distracting then you should do something about it.
    I think the first thing to try is to check if it's an earthing problem by moving the sub to a different plug socket. Try the same one as you have your amp in.
  3. mortonman
    mortonman
    Cheers,
    I will try another plug or socket as it didnt do it in my old house. It must be something to do with the mains as it is still there whether the sub cable is in or out !
    Matt
