Rel Q-150
Discussion in 'Subwoofers' started by sTTu, Mar 21, 2003.
  1. sTTu
    sTTu
    Feb 10, 2003
    193
    +21
    Is it a good sub ?
    sTTu
  2. Hareraiser
    Hareraiser
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    Alternatively, listen for yourself and make up your own mind.
    The short answer - it's an excellent sub within the limits imposed by its size. This month's Hi-Fi Choice reviews it and rates it highly, as does Home Cinema Choice.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Can only speak for its larger sibling,the Q201....I've found it to be a very good sub in the room and setup I use,with a decent bass extension and attack.
  5. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Depends what your requirements are.
    Having listened to it I don't feel it's a great performer. Not terrible, but certainly not worth the lavish praise the press heap on it.
    However, it's as discreet as could be, and for most living rooms it's a superb compromise - just don't expect it to rattle your fillings, if you have a dedicated room where aesthetics are not crucial you could do better for the money IMHO.
