Alasdair Mackay
I have a choice of a Rel400E or MJ ref1 any advice on which to buy. Both about £350.00 each. All help appreciated.
I feel a BK Monolith coming on.russ.will said:Are you limited by size and is £350 the max.
Russell
Without a sub, I can't imagine that you 'feel' anything.Dynaudio Desire said:I feel a BK Monolith coming on.![]()
russ.will said:Without a sub, I can't imagine that you 'feel' anything.![]()
Russell
I have got 2 15" bass bins each with an output of 500 watts. And soon to be adding a 18" 1000 watt active one. So dont worry Russ I know how to feel my bassruss.will said:Without a sub, I can't imagine that you 'feel' anything.![]()
Russell
Budget about £600 Room size about 6m x 5m. sub at present Jamo. Not bothered about sizeruss.will said:Are you limited by size and is £350 the max.
Russell
Well,i have the ref1.I use it in a 5m:3m room.For optimal coupling to this smallish room and to match my insensitive speakers i use just 30% gain and the sub-channel level is -5 db.Also it cant go very low and it is not very even as well-i am talking about my room.And it needs a hard floor or a good isolation.But it is fast and musical and i know that it would drive a bigger room like yours better.It can still shake the house and the neighbours house with certain program material.I havent heard the Monolith though.It looks better on paper and has rave testimonials.Robin-Hood said:I have a choice of a Rel400E or MJ ref1 any advice on which to buy. Both about £350.00 each. All help appreciated.
It is a good sub, and at £350 its about the right price. If you are ever near Cambridge, PM me for a home demo and I'll upset you.Robin-Hood said:Russ and all helpful advice. I have gone for the MJ Ref 1 Mk 111 decided I would buy new in the end as everthing else I have just purchased is new, just getting some driving practice in. I am over the moon with my Denon 4306 and 3910 but a bit ****** off with Denon as 4 times now they have said they would send me the upgrade for my 3910. Who knows it may turn up on Thursday I can then use the Denon link. Anyway thanks for all the help.
