Rel crossover help needed
Discussion in 'Subwoofers' started by big ric, Oct 23, 2004.
  1. big ric
    big ric
    At the moment i own a rel stadium 1 sub but next week i am getting a rel stadium 3 i want to use them together for music the problem i have at the moment is setting the crossovers i know the 3 as a 12dB/octave cutoff but i dont know what the 1 has i have asked rel and i am still waitng for a answer can anybody help
    Thanx
    Big Ric
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,664
    7
    167
    Birmingham, UK
    +10,545
  3. Cmoth
    Cmoth
    Apr 21, 2004
    1,150
    38
    Hertfordshire
    +22
    the sound characteristics of the Stadium 1 and 3 will be so different , so i strongly suggest you dont try what you are suggesting! - I have owned a stadium 1, storm and a stentor over the years - the 3 will wipe the floor with your current one. I agree, get a 2nd hand stentor instead if you can afford it , it will sound much better, or just stick with the Stadium 3 for music - possibly stick the stadium 1 on point 1 channel if you really want to use it.
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    Yes, I agree, I have a Stentor 3 and it is in a completely differetn class to the Stadium. It would be well worth selling your Stadium 1 and using the funds to get the Stentor 3.
