REL ABC Question
Discussion in 'Subwoofers' started by Buckster, Mar 23, 2005.
  1. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Another Storm I question - sorry
    Am I right in thinking the ABC filter does nothing for the low level phono inputs ?
    Its just I was doing some setting up today - and had ABC set to 60Hz - yet was still getting 90Hz + out of the sub ?
    Cheers, Mark.
  2. Duffers0
    Duffers0
    Not sure on the Storm but on the Quake you have 4 settings. Number 1 is in phase for both HL and LL and controlled by the cross over, on the sub.
    Setting 2 is no roll off for LFE low Level, roll off cross over setting only applied for HL. Therefore you are controlling roll off for HL for music from speaker terminals but your AV amp through your LFE settings is controlling HL phono connection.
    Setting 3&4 are the same as 1&2 only in 180 degree phase reverse.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    The ABC filters will only function for the low level input if the mode switch is in mode 1 or 3.
  4. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Thanks guys - sorry I forgot to respond to the thread.
    It was indeed that only the "high levlel inputs" are effected by the ABC control ....
    I don't have any modes on my Sub.
    Thanks again, Mark.
