floatingkiwi
I bought a second hand 212 and the high level inputs work fine, as expected. The LFE input however is so low that with the dial at max gain the Denon setup is barely getting into the green "sub is ok" level to start setup.
Previous subs are a REL storm 5, and dual BK XXLS400's. I also have REW which confirms what I'm seeing. Same cables, position etc used for direct swap between 1 xxls400 (for example) which ends up with a gain of about 10 ockock on the dial, which is about right. So no faults with any other part of the gear.
REL was contacted and continued to send me" setup for dummies" emails and eventually stopped responding, even when contacted through the NZ distributor.
This thing has a gain problem on the LFE input, and the only way to fix it, it seems, is to buy a very expensive complete new amplifier plate.
Thoughts? If I had bought it new no problems I guess.
