REL 201 Hum Fixed
Discussion in 'Subwoofers' started by AshF, Apr 11, 2002.
  1. AshF
    AshF
    Jul 1, 2001
    23
    Like many people I had a hum coming from my sub. I'm connected to the low level input and I'd tried everything suggested, different cables, different power source etc. Then the other night I decided to have another play to try to sort it out. The problem in the end was that the high level in volume was set to max, when I turned this down to min all humming disappeared. Quite obvious really! Also I don't get the initial thud when I switch on now. Was this documented in the manual? Has it been in this forum before?
    Ash.
  2. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I noticed the exact same thing when I borrowed a Q201.
    As you say, turning the volume down solved it.
    However, if you 'terminate' the high-level input (i.e connect it to a speaker or amp) as its intended, you won't get the hum either as there will now be load on the amplifier circuit!
