Reinstall outlook on XP
Discussion in 'Desktop & Laptop Computers Forum' started by Taz, Jun 21, 2004.
  1. Taz
    Taz
    Hi guys, I need to reinstall Outlook Express on my XP machine but when I try with V6 it gives the error that I have a newer version of IE and its terminated.
    Can anyone please help
    TIA
  2. Taz
    Taz
    Anyone :lease:
  3. pcdoc
    pcdoc
    Feb 11, 2003
    140
    +3
    the way I would do it is go to control panel, add remove programs, hit windows component icon then remove the tick. This should uninstal IE, then reinstall. or you could try installing Mozilla Firefox I use that more now has a better built in pop stopper and download manager. Afterall IE is based on mozilla. get it here http://www.mozilla.org/products/firefox/
  4. The Dude
    The Dude
    May 21, 2004
    6,270
    Beverley, East Yorkshire
    +2,593
    ** If you're happy working in the registry** this will get you around the problem..
    Click Start > Run > Regedit > OK
    Open up the following registry key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{44BBA840-CC51-11CF-AAFA-00AA00B6015C}
    right-click the IsInstalled (REG_DWORD) value, and then click Modify.
    Change the value data from 1 to 0, and then click OK.
    Quit Regedit, then reinstall Outlook.. You shouldn't get the error this time..
    ( Entirely at your own risk of course.. ;) )
  5. Taz
    Taz
    Thanks guys. :smashin:
