Reinstall or repair after motherboard upgrade?
Discussion in 'Microsoft Windows' started by Pudgerboy, Sep 18, 2007.
  1. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    hi,
    i am upgrading my motherboard, ram, processor and graphics card, so basically im just attaching my drives to a new system. Since the install of MCE is registered to that hardware, will i have to reinstall and reauthorise with such a big hardware change? I'm assuming that my current install will blue screen with the different motherboard. I'm thinking that a fresh install is never a bad thing to do but didn't know if there was a quicker option without reinstalling everything. cheers
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    yes and yes, fresh install is the better option with such big hardware changes...less problematic as well (fingers crossed)
    Curly
  3. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    Thanks Curly,
    I plugged everything in just to see if it would work and it did indeed boot. Just needed to re-authorise Windows but it seems okay. If i get any issues i will reinstall but for the moment i will go for the quick option!
