Regions
Discussion in 'Blu-ray & DVD Players & Recorders' started by mobily, May 13, 2005.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hey all,
    I have a dvd player that supports progressive scanning (PS). However it only supports ntsc for PS. Does region 3 class as ntsc also or will PS only work on region 1 discs?
    James :)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Region coding has nothing to do with the format in which the DVD is encoded. For example Region 2 includes Europe (most PAL) and Japan (NTSC). Thus when you buy discs you would need to look for NTSC format and not region coding!
    Region 3 discs come from Hong Kong and the Far East. Phillipines, South Korea and Taiwan are all primarily NTSC. Hong Kong is PAL (although, never having been there, I cannot vouch for the reality of this). Whatever I would suggest North America is a better source for NTSC discs.
    If you have a NTSC PS DVD player only then I would recommend upgrading!
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    FWIW, my R3 Hong Kong editions of Sky Captain... and I Robot are both NTSC. Can't speak for other titles.
