Region Unlocking Toshiba SD230 DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by GarethLewin, Jul 29, 2003.
  1. GarethLewin
    GarethLewin
    Does anyone know if/how it can be done. I have an LG right now which was just a remotecontrol thingy. The V633 is for sale on some sites as SD230UK and some as multiregion.
    Any idea what is needed to 'unlock' it ?
  2. GarethLewin
    GarethLewin
  3. allen6000
    allen6000
    The link refers to the SD220. How did you get on with your SD230?
    Thanks.
  4. GarethLewin
    GarethLewin
    I haven't actually tried it yet, I didn't notice the model differance.
    Hmm, but at the end of that thread someone says
    As it turns out, all my Region 1 DVDs are lent to other people, and I only got my machine a week ago, so haven't needed to try. But I will ASAP and get back to ya.
  5. GarethLewin
    GarethLewin
    I can now say that I have tested it, before I used the cd I got a message saying "Invalid DVD" (or something like that), after burning the patch (the link at the bottom, the first one is corrupt) and running it thru my DVD (for more than 10 seconds) and turning off and on again, the Region 1 DVD worked like a charm
