Region Problem With Pioneer 106S DVD-ROM
Discussion in 'Desktop & Laptop Computers Forum' started by Orbital, Sep 24, 2001.
  1. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Hi All <img src="smile.gif" border="0">
    I've got a Pioneer 106S DVD-ROM drive and I want to make it region free. I've tried flashing it with the latest firmware from <a href="http://www.firmware.fr.st/" target="_blank">www.firmware.fr.st</a> But all it seems to do is reset the region countdown, you know the one where you get 5 or is it 6? attempts at setting the region before it becomes fixed. I just want it to play any region straight off. Am I asking the impossible? or is there a trick I'm unaware of?
    Dave
    [ 24-09-2001: Message edited by: Orbital ]
    [ 24-09-2001: Message edited by: Orbital ]</p>
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I think the site has a utility to check the drive. Most likely the drive is multiregion now, its the software region checker that is coming up with the message. DVD Genie is the program to use to reset/bypass the software region check. I'm not sure if you can automate it in a way so that no message is displayed but it does at least let you reset the counter.
    Jeff
  3. fatrich
    fatrich
    Jun 21, 2001
    2,613
    71
    halifax
    +53
    i had the same problem with my pioneer try using dvdkiller.com that may sort out your problem
  4. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Fatrich is that <a href="http://www.dvdkiller.com?" target="_blank">www.dvdkiller.com?</a> I've tried that address but it comes up with a "This site is under construction" mesaage.
    Dave
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Here you go.
    <a href="http://www.divx-digest.com/software/dvdkiller.html" target="_blank">http://www.divx-digest.com/software/dvdkiller.html</a>
    Jeff
  6. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Thanks Jeff, again!! <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
    Dave
  7. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Ha ha! Don't get rid of me that easy!
    Am I missing the plot here or am I just being dim? (don't answer that) <img src="smile.gif" border="0"> It's just that the dvdkiller utility just seems to be for ripping DVD's How can this help my region problem?
    Dave
  8. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Orbital, try going to this site.<br /><a href="http://perso.club-internet.fr/farzeno/firmware/dvd/dvdfi.htm" target="_blank">http://perso.club-internet.fr/farzeno/firmware/dvd/dvdfi.htm</a><br />Find your dvd-rom, and sort it.Then go to<br /><a href="http://www.visualdomain.net/" target="_blank">http://www.visualdomain.net/</a><br />and download Drive Info. This will tell you whether your dvd-rom is region free or not. <br />Good luck,<br />Ken
    [ 27-09-2001: Message edited by: Ken ]
    [ 27-09-2001: Message edited by: Ken ]</p>
  9. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Give DVD Genie a go <a href="http://www.inmatrix.com/files/dvdgenie_download.html" target="_blank">http://www.inmatrix.com/files/dvdgenie_download.html</a>
    Jeff
  10. fatrich
    fatrich
    Jun 21, 2001
    2,613
    71
    halifax
    +53
    Dave <br />sorry for not giving the correct e-mail address Jeff has given you the correct address, hope it helps
    richard
  11. Arthur.S
    Arthur.S
    Yep, I've been using DVD Genie for over 2 years now. Works a treat.
