Region Hacks for PC-DVD
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by tiggy, Oct 4, 2001.
  1. tiggy
    tiggy
    Hi all,
    Apoloigies if this as been asked before,or if this is not the right sort of forum to ask this but, I've just received aload of Region 1 DVD's this is not a problem as I own a Multiregion Player, but I also have a DVD drive in my PC,(Creative Encore Dxr3) but it's set to region 2. And as you know, Your only aloud to re-set this 3-4 times,(which I don't want to do).
    So is there a program that will let me change to a Multiregion Drive,
    Very much appreciated.
    P.S
    If there is such a program, would this reduce the life of my Drive.
  2. Guest
    Jim,
    No sweat. There are plenty of places on the net where you can find programmes that will allow you to change regions. Take the time to look, they're out there.
  3. Xevian
    Xevian
    Oct 3, 2001
    62
    9
    Farnborough, Hants, UK
    Check out http://www.firmware.fr.st/ for a new RegionFree firmware for you drive, You could also try the Hollywood+ Software instead of the creatiev stuff and the use Zone Selector.
