Region Hacks, a question.
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by General Skanky, Nov 2, 2001.
  1. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    I understand that a hack is either an alteration in the service menu to 'enable' extra functions switched off depending in which region you live in, or an added IC loaded with software to enable those functions not normally present.
    So here is the question, and remember manufacturers are 'supposed' to be supporting the multi region thing, where do the hacking companies like Techtronics get the relevant software from to do these hacks???? Surely the manufacturers don't divulge the info, as they may as well have done it in the first place and sold a multi region player! Isn't there an agreement of some sort to prevent manufacturers doing it?
    This goes for all players as hacks are available for them all. Either we are being taken for a ride or there is a magical way of getting the software required for each player, which would mean any of us could programme an IC ourselves with any home pc and fit it DIY. Someone is making good money. Or am I just thick? :)
  2. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    It's all about money. If it can be hacked it will be..........:eek:
    If we want it, we pay for it.................:eek:
    All the chip making companys that make the chips make a mint !!
    The companys that fit the multi mod chips make a mint !!
    While we are left sucking a murry mint ............!!.........skint
    Most studios are not yet using RCE encoded disks. What will be next.....?
    Every time they change it cost around £45.00 for a new chip....:mad:
    You need any KING size Rizla with that smoke............:p puff puff
  3. encaser
    encaser
    Mar 15, 2001
    3,612
    Suffolk/Essex
    +1,221
    True, true. Not all players can be hacked without a physical mod due to pathways in the chip/dvd design. This really is Hollywood etc being tight gits as per. There is much debate about region coding and its side effects, as lab tests have been reported as indicating that region designed chips can have a deletoriuos effect to video performance. But then Hollywood etc. carry the weight with dvd producers and we get screwed. As DTS Borg notes about RCE as another method to try to prevent cross-border sales. Only omnipresent hack is to be found in pc's, a method I've tried and works fine.
    Time for a cup of tea and a smmmooookkke. Spin that St. Germain
