Region Hack For Pioneer 105, And General Hack Question.
Discussion in 'Desktop & Laptop Computers Forum' started by Garrett, Sep 3, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    38,997
    2
    167
    The best thief you’ll never see.
    +6,176
    My CD burner seems to be having some problems which is forcing me to look at a replacement. My mate is going to purchase a Pioneer 105 or 106 within the next few days and I very well get one at the same time. Does anyone know a region hack for it?
    Also I have heard once it has played a region 5 times it is locked into that region if there was an hack do they work after those 5 times or has it to be implemented before
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    105 has modded firmware, 106 needs a workaround at the moment, look here ;)
  3. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    If you are worried about firmware the region killer products from www.dvdidle.com work well, but you MUST set the drive to a region of your choice first, otherwise the software players just hang.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,133
    +1,179
    I would have thought the firmware hack on the 105 would work even if the drive had been changed 5 times and locked.
    Not sure about the 106 and regionfree working after lock though.
  5. Kramer
    Kramer
    Yep, it doesn't matter if the drive has been "locked". Flashing will permanently make it RPC1 - i.e region free.
    Have an A05 (OEM 105) & flashed with updated firmware. Lots of other benefits aswell as region free.
  6. Garrett
    Garrett
    Apr 21, 2001
    38,997
    2
    167
    +6,176
    :eek: :eek: :eek: Whats them?
  7. Kramer
    Kramer
    Rip speed limitation defeated, compatible with more media, faster burn speed (eg. 4x rather than 2x with certain media). Think there was one/two more things mentioned too :eek:
    Can't complain about the 105/A05 - excellent performer & (now) cheap as chips.
  8. Garrett
    Garrett
    Apr 21, 2001
    38,997
    2
    167
    +6,176
    You’re not orange are you.:D ;)
    :smashin: Thanks everybody for all the help:smashin:
