Region Hack for Bush TV
beckybinghamx
I'm from the UK and have a DVD from Australia. Every time I try to enter it says "wrong region DVD" I have a Bush 32inch (LE-32GE11E+DVD) tv and DVD player combo. Are there any hacks available for this model? Thanks!
fixer
Bit of pain this tv try going into menu now press the down arrow 4times so nothing is hilighted ie the timer ect now press 0zero 4 times and then i think you hold the left arrow key and menu key and the greenkey together now u should get the engineer s menu u might be able to turn region off that way cant day if u can tho i only had the same tv minu s the dvd part might take a few goes to get the key pressing right and do not fiddle with any other settings oh and if the remote stops working use the side keys on tv to turn to another channelport then go back to engineeringmode and do a tv reinstall or facotory reset if all goes wrong i take no liability for bad things wrong
