Region hack for Bush DS-A241
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by maggie0388, Feb 11, 2009.
  1. maggie0388
    maggie0388
    Hiya,
    Does anyone have the region code for this machine? My boyfriend bought it at argos, he is in the navy an is currently in Brazil and cant get the dvds to work in it.
    Any help would be appreciated.
  2. Spike77
    Spike77
    There is some confusion with this one as it has been known to play all Regions without a hack.
    What i did with mine was.......
    Open tray and leave open
    Press set up menu and punch in 1389
    This opens up the technical page but from here nobody knows how to unlock the Region 2 status.
    I then turned off the set, turned on again and went to set up menu, select preference and choose NTSC
    and now my player plays all Regions, i have no idea if the 1389 route is key, it may well be that you only have to set preference to NTSC anyway !
    Good luck.
  3. mentat75
    mentat75
    Jun 23, 2009
    Hi, I tried using your hack and it seem to almost work but not quite. I was wondering if you had anymore info on how to unlock region 1 for it. Thanks.
  4. Rogerborg
    Rogerborg
    Sep 23, 2009
    4
    :thumbsdow
    Doesn't work for me with:
    Version 0C.00.02.00
    SUB-VER 08.08.07.01
    8032 0C.00.02.00
    Servo 05.04.F2.00
    RISC 0C.00.02.00
    DSP 12.09.00.16
    Region Code 2
    Setting the output to NTSC makes no difference. Region 1 discs still barf with "Wrong region"
    If this does work for you, can you please post your version (eject, setup, 1389)
