Region free for a PC dvd player??
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by jonjon, May 18, 2004.
  1. jonjon
    jonjon
    Can and how do you region free the DVD players and writers on Dells computers?
    one'e NEC, one's Samsung.
    I have heard it can be done????? :confused:
  2. joegib
    joegib
    Jul 13, 2003
    77
    London, UK
    +10
  3. lead
    lead
    Aug 19, 2003
    653
    +62
    Unfortunately, it's not as simple as just updating the firmware of the DVD player. :( There is region protection in Windows and in the software you use to watch DVDs. :rolleyes:
    Take a look at this for starters:
  4. cyclops12
    cyclops12
    there is a small program called anydvd this just runs in the backround it makes all dvd's region free it also removes copy protection :devil:
    hope this helps!!
  5. joe davis
    joe davis
    DVD Decrypter 3.2.2.0
    Rate It Excellent . region free and rce free program.
    License Freeware
    Price FREE
    OS Windows All
    Size 770 KB
    Download Time 56K: 1m 50s 64K: 1m 36s 128K: 48s 768K: 8s
    Last Updated April 26th, 2004 10:00
    Category C: \ Multimedia \ Video \ Other VIDEO Tools
    PRODUCT DESCRIPTION
    SPONSORED LINKS
    · Anti Tracks 2.2
    · TuneUp Utilities 2004
    get listed
    DVD Decrypter is a free tool which enables you decrypt and copy a DVD to your PC's hard disk.
    From there you can choose to watch them with the likes of PowerDVD and WinDVD or you can re-encode them to MPEG1 (VCD) or DivX.
    Advanced functionality can be found in the context menus.
    What's New in This Release:
    · Added: 'RCE Protection Found' dialog box
    · Added: Apply button to the 'Change ISO volume name' dialog box
    · Added: Eject / Reinsert of disc before the verify stage
    · Added: Support of brute force disc key cracking
    · Added: The ability to have the program not ask you if you want to erase / overwrite a disc in ISO Write mode
    · Added: CLI support for '[DISC_LABEL]' in destination path names
    · Added: CLI support for '/SPLIT 1GB' - Only for IFO mode
    · Added: Additional error checking to IFO patching code so that 'invalid' IFO files are easily spotted and pointed out to the user
    · Changed: 'Pack Header Not Found' warnings are now also shown in ISO Read mode so as to warn the user of potential problems
    · Changed: What's displayed in the info panels in ISO Read/Write mode is now not so dependent on what the 'Current Profile' is. It now also works by the discs 'Book Type'
    · Changed: Some of the code behind setting the drives 'Write Parameters'. This may work out better for people who said they were having bad burns from 3.2.1.0
    · Changed: Some of the disc initialisation code to use single commands to get and display the 'state' of a disc (i.e. Empty, Complete), so that what's displayed in the info panel in ISO modes is what the program uses.
    · Fixed: Problem with drives (i.e. AOpen ones) that make use of multiple AGID values as part of Authentication
    · Fixed: Write speed control wasn't correctly being set to its last saved value
    · Fixed: Older Pioneer writers (i.e. Pre 107) weren't burning some CD images properly
    · Fixed: Ejecting the disc after erase, before burn - it shouldn't have been happening
    · Fixed: Problem with invalid characters in filenames (generated from the disc's volume label)
    you can get it here. http://www.softpedia.com/public/cat/11/2/5/11-2-5-1.shtml
