Region free DVD's on DV88+
Discussion in 'Arcam Owners' Forum' started by Cameron, Apr 19, 2004.
Tags:
  1. Cameron
    Cameron
    hi there, I bought my self 'Beatmaster' on DVD. IT says on the back region free. When I try it in my (mult-region) DV88+ I get sound but a blocky unwatchable screen.
    On my computer I can see the DVD fine. Do I need to select something (or input something into my remote) for region free dvd's?
    thanks
    CaM
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    Over the Hill & Far Away
    +119
    No... should work fine if you region is set to 13 on the player.
    Matt
  3. Cameron
    Cameron
    it is the only one out of my dvd collection that suffers this problem - but it may well be the only region free dvd I have.
    I'll investigate further I think.
    thanks
    CaM
  4. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    CaM,
    As Matt has said it should work OK if yours is set as 13. I think you can set the player to be region 0 as well as multi region. Certainly region free DVD's play OK on my DV27
    Regards
    John
  5. Cameron
    Cameron
    Ok, I'll investigate tonight to see whether my player is region 0 or region 13 and report back.
    thanks
    CaM
